It is currently Sun Aug 17, 2025 10:30 pm
PostPosted: Thu Mar 25, 2010 9:06 am
Last Name: Ensor
City: Springfield
State: Missouri
I am looking in to eventually making myself a classical guitar. I have never made a slotted headstock, though I think I understand the process. I would like to see your templates/jigs you use to cut the slots and drill the tuner holes. And if anyone knows of a cheaper alternative to the stewmac version of the drilling jig (http://www.stewmac.com/shop/Tuners/Tuner_installation_tools/Tuning_Machine_Drill_Jig_for_Slotted_Pegheads.html?actn=100101&xst=3&xsr=12203), that would be helpful as well.
I think I remember how Sergei slots his headstocks, so I will try to make a fixture like he has. Sorry no pictures. But if you have any ideas of a good way to do this (I will be using a plunge router) I would appreciate your input. Thanks
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Thu Mar 25, 2010 9:30 am
Not cheaper than the Stewmac or LMI jigs by any means, but check out the headstock jig @ http://www.luthiertool.com/classical.html . One setup for drilling the tuner holes and for routing the slots. I probably should have tried it by hand before I bought this jig, but it is really nice and I don't regret buying it. It gets the tuner holes dead-on if you use 3-on-a-plate tuners. I got the combo set for classical and steel string style slots.
PostPosted: Thu Mar 25, 2010 10:16 am
Ditto on the Jonathan's recommendation. It's the BEST (and only) jig I have ever bought.
PostPosted: Thu Mar 25, 2010 10:46 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Fun, huh? I built my first jig and quickly learned why the jigs you can buy are single sided. Fortunately, I practiced on scrap befor using on the peghead. Single sided, good. Flip over and use on other side. :)
There is a very useful file you will need for sculpting the end of the slots where the strings exit. Dangit! I cannot remember the name of it, but if Todd chimes in, he can tell you. Strongly reccomend this!!
PostPosted: Thu Mar 25, 2010 10:51 am
Forstner bit, and a low fence to keep even with edge of headstock. Clean out with files and sanding sticks. Very simple. Very cheap.
PostPosted: Thu Mar 25, 2010 11:12 am
Last Name: Abercrombie
Chris-
You've taken Sergei's course (?) so you know his system.
I found that it worked well recently when I dug out my notebook and made up a jig to do a classical headstock.
I don't think you need a jig to drill the side tuner roller holes, if you are careful with your layout.
Be sure to drill the tuner holes before slotting, as Sergei taught.. the pic shows the jig in place for trimming the outside of the headstock. The slotting was done later. I cleaned out most of the slots with a couple of forstener holes and the jigsaw, then a pattern bit (not plunged) to follow the template.
BTW, I do know how to tie on the strings better than this! I was in a hurry to string up!
PostPosted: Thu Mar 25, 2010 12:08 pm
I realize the template pic is not very clear at all...
The plywood template is screwed to the rough headstock with three FH screws - two short screws into the area that will be the 'string ramp' and the third in the excess waste area at the very top of the headstock.
There are a couple of larger holes on the centerline for aligning the jig with the centreline of the headstock and the nut area.
Of course, to make the template, I made a template....it goes on and on!
I generally do the 'decorative bit' at the end of the headstock without a template, or use a separate template for that.
PostPosted: Thu Mar 25, 2010 12:28 pm
I too use the luthiertool jig....Not cheap but fantastically made and it makes slotted headstocks a breeze
PostPosted: Thu Mar 25, 2010 2:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
You talking about that aluminum thingy? I want one. I really want one!!
PostPosted: Thu Mar 25, 2010 2:16 pm
State: Hessen
While on the subject: I am aswell interested in getting one of those aluminum thingys from luthiertool.com, but as a not-native speaker of the english language I am confused by the options and different versions they offer. idunno
I am interested only in making steel string guitars with slotted headstocks. What do I need? The "Classical slot head fixture standard" together with a "Standard template set (for steel string)"? Would I need the "Classical drill bushing set" at all?
duh Me so confued. gaah
PostPosted: Thu Mar 25, 2010 2:41 pm
duh Me so confused. gaah
I'd suggest dropping an email to them- surely they won't make you buy something you don't need?
chris@luthiertool.com
Be sure you have the correct router adapter as well. (for example, the Bosch routers need an adapter plate to use the standard round bushings.)
PostPosted: Thu Mar 25, 2010 2:42 pm
For drilling the roller holes, the Gilbert drilling block at $35 is good value
http://www.specialtytuners.com/ look under tooling.
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Christoph, for steel string slot head only, you would need this model from Chris at $249.
Coincidentally, I just took delivery of a box of goodies from Chris yesterday, including the combo version of the slot head jig. [:Y:]
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Thu Mar 25, 2010 2:49 pm
State: Hessen
John, Dave,
Thanks a bunch. [:Y:]
PostPosted: Thu Mar 25, 2010 7:20 pm
yep
PostPosted: Fri Mar 26, 2010 6:00 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Like Waddy I use a forester bit and a fence on my drill press to rough out the holes and then finish with files and sandpaper. I do use this Stew Mac jig to drill the tuner holes.
http://www.stewmac.com/shop/Tools/Special_tools_for:_Tuner_installation/Tuner_Drill_Jigs.html?tab=Pictures#details
Drilling the tuner holes first eliminates blowout in the slots.
PostPosted: Fri Mar 26, 2010 6:46 am
First name: David
Last Name: LaPlante
Here's mine,
I made these templates well before anything was available commercially and had access to a milling machine at the time.
This one is fastened with screws in the location of the future slots
Stew Mac drilling jig:
Template is fastened at the waste corners of the peghead and neck center line
with short wood screws
PostPosted: Fri Mar 26, 2010 7:34 am
Country: Romania
I'm sort of envious on you guys. I just scribe mine with a marking gauge then carve with chisels and finish with rasps and files. It's a lot of work and I guess I just like to complicate my life :)
For the barrel holes I use the LMI guide with steel bushings.
Build log
PostPosted: Fri Mar 26, 2010 10:10 am
I do the same and it's a lot of fun doing it that way. I think I may have the same LMI tool as well, I got it like 15 years ago and still works like a charm. It's just a simple machined AL block with bushings.
Users browsing this forum: Bing [Bot], TimAllen and 35 guests
